Hello geeks, Is it possible in to program a menu login jquery based ? The challenge would be to integrate it into a site that contains no JavaScript code. Knowing that JQuery requires all its library to be loaded, do you think my scenario is realistic ? Thanks a lot
Code a menu login jQuery based
Hello Dear,
Your approach is not realistic.
It can not be done like that.
It is not possible to program a menu login that is jQuery based.
I'm not sure anyone can do it.
It will be a very difficult job.
Yes this is still possible.
JavaScript makes websites easily accessible and user-friendly to all computer users but there are some websites that does not have JavaScript at all.
So to be able to add a login function using jQuery, you will need to use DOM (Document Object Model) scripting, and it should be an unobtrusive DOM because it is the only one that can allow you to add JavaScript to your website where there is no presence of JavaScript at all.
To get more information about how to use DOM, simple click on this link.
Hello!!
I am very glad to receive your interesting problem. I am giving some clear solutions.
You can use the attached code create menu by jQuery But you can’t create as you want.
You have to create a function and define a variable like y=l.jQuery in the .jquery.js file.
In the menu.js file You have to define color as your choices.
Regards
Shifflett Laurel
