A code for menu slide up and down on a web page.
There is this website am supposed to build, can someone help me with a code that can help me add a menu slide up and down onto my web page?
Hello Annie,
You are looking for code for Menu slide up and down to your web page. Here is some instruction for getting this opportunity and embedded into your webpage. Menu slide down and up are generally working with using JQuery and CSS3. Like this picture.
Using the code you will able to slide out item of the menu.
You need to use an unordered list with item associated main link and div content for submenu.
For CSS you also can use text decoration, outline, shadows, spans, positions style and so on.
Using JavaScript you also can use sdt_active span and wrap span in any side right or left.
To see all the code Slide Down Box Menu with jQuery and CSS3 | Codrops
Thank you.
