Code publisher 2000 to register
I want to install publish 2000 separately. It needs a registration code to register it. Where can I find code publisher 2000 to register properly?
Hello Dennis,
To register Publish 2000, you will need to have a registration key. If you installed the application from a CD, you will need to check it for that key. It should be there.
But if you downloaded the application from the internet, you will need to go back to the internet from the site you downloaded from and search for the key.
Carl
Hello Azal,
The registration key you are talking about it should be in the installation folder of Publish 2000. Sometimes they put the key in another folder so recheck the folders again. But if you downloaded publish 2000 and any kind of connection failure or error happens while downloading it. In that case, it is possible that the key missed out then. So I can suggest you to download the file and try to install it again. Hope this time you’ll find the key.
Good luck
Notifications
