CoffeScript error occurred when tried to check syntax
Anytime I try to attempt to do something like check syntax (Alt+Shift+S) but nothing happens and receive the following error message saying “Env: node: no such file or directory”.
I can’t get any command for this plugin to work.
Can I get solution to resolve this matter?
CoffeeScript
Env
Node: No such file or…
Env: node: no such file or directory.
Answered By 5 points N/A #176850
Your coffeescript might be coupled with another plugin in the same directory.
Go to Coffeescript – sublime build then edit the path to:
"path": "/usr/local/share/npm/bin:/usr/local/bin:$PATH"
The line above will fix the build command but not the compile command yet which of course, includes checking for syntax errors.
By default, Homebrew installs the executable node to:
/usr/local/bin
Which is separated by binDir
So, on the compile command, call
run("coffee", ["-c", "/whatever/script.coffee"])
In run command, create an env variable.
proc = Popen(command, cwd=cwd, stdout=PIPE, stderr=PIPE)
