I stumbled upon this cool app called coins pirates java. A game where you can drop some coins and spin the reel, then you can get tons of treasures> Quite an interesting game. I would like to know if you know some cheats and techniques for this application.
Coins pirates java app help
Hi Donal, you can try this steps.
1. Drop coins in coins slot as much as possible- this will give you more chances of pushing coins, if you queue for treasure, lot of machine slot, more coins can drop
2. Don't cash right away your treasured items- the more items you save, the more coins you are going to have, let them pile up and use them when you need
3. When your coin is less than fifty, play them slowly- pace yourself with the increased amount of time you can kill,
4. When the slot stops and you are running out of coins- walk away and come back 20-30 minutes, when you return, you will get 40 to 50 coins.
5 Drop coins at once on each slot … you can try this what will happen.
Coin will increase as time passes by.
Hope this help.
