Collegiate font for ms word
Hi Experts,
I am looking for collegiate font for ms word. I am using Windows XP and trying to install the collegiate font for ms word but i cannot install in windows XP. Please suggest me the proper solution with downloading link of collegiate font for ms word.
Anant vijay soni
Best Answer by jamesmutua007
Answered By 0 points N/A #163198
Good Day Anantvijay,
There are many types of collegiate font and there are also a lot of sites wherein you can download these fonts. Below are couple of sites wherein you can download them for free:
https://www.dafont.com/sf-collegiate.font
http://www.fontspace.com/category/college
With regards as to how to install these fonts, you can browse the site below and follow their comprehensive step by step guide on how to install fonts on OS Windows XP.
http://www.microsoft.com/resources/documentation/windows/xp/all/proddocs/en-us/windows_fonts_addnew.mspx?mfr=true
Regards.
Answered By 0 points N/A #163199
hi,
first  you need to download the font and save it to c:>documents and settings then you have to extract all the settings that is if the folder came as a zip folder
2.find the fonts link in the control panel.Click this Fonts Icon box and a screen with every font in your computer should come up
3.Go to File>Install New Font>
A dialog box should come up and when it does go to the area in the box that says "Folders" Click c:/>Documents and Settings> and then your Font should be there.
4.Now click the font and it should come up in the "List of Fonts". Click OK, and now it will be in Microsoft Word.
Answered By 590495 points N/A #327698
If you want to use collegiate fonts in Microsoft Office Word, try downloading from the following websites:
Once you’ve downloaded the fonts you like, installing them is easy. Click “Start”, “Control Panel”, “Appearance and Themes”, and then click “Fonts” on the left pane. On the next screen, click “File” and then “Install New Font”. Navigate to the location where you downloaded the fonts then click “Select All” and then “OK”.
Once the fonts are installed, you can now use them when composing a document in Microsoft Office Word and other programs. If the fonts you downloaded are in ZIP files, unpack them using 7-Zip.
