Color availability of Nokia 808 PureView in USA?
In how many colors will Nokia 808 Pureview be available in the USA? I have heard it comes in three colors, but will they all be available in US?
Colors that will be available in USA are white, black and red. Nokia Pureview 808 is 580 USD pre ordered. The device is equipped with a 1.3 GHz single core ARM 11, 1 GB of ROM, 512 MB of ROM and 16 GB of internal memory, which can be further expanded up 32 GB via microSD card. Nokia 808 PureView sports a vivid 4.0-inch AMOLED capacitive touch screen display that supports 360 x 640 pixels resolution.
The Nokia 808 PureView Smartphone is a 3G device operating on 2G and 3G bands using GSM and HSPA technologies. This model was unveiled to the public on February 2012 and released on June 2012. It is currently available. It measures 123.9 x 60.2 x 13.9 millimeters and weighs 169 grams. It uses a micro-SIM card. It has an AMOLED capacitive touchscreen display with 16M colors at 360 x 640 pixels screen resolution.
It supports multi-touch and protected by Corning Gorilla Glass with Nokia ClearBlack display. It runs on Nokia Belle OS powered by 1.3 GHz ARM 11 processor, and Broadcom BCM2763 GPU. It supports microSD expandable up to 32 GB. It runs on 512 MB RAM with 1 GB ROM and 16 GB internal storage. The primary camera supports 41 megapixels at 7152 x 5368 pixels with Carl Zeiss optics, autofocus, and Xenon flash.
The camera features geo-tagging, 1/1.2' sensor size, ND filter, and face detection. It can record video in 1080p at 30 fps with 4x lossless digital zoom. The secondary camera can record video in VGA at 30 fps. It supports Wi-Fi 802.11 b/g/n with DLNA, and UPnP technology, Bluetooth 3.0 with A2DP, GPS with A-GPS, NFC, and microUSB 2.0 with USB Host.
The Nokia 808 PureView Smartphone has built-in accelerometer, proximity, and compass sensors. The pre-installed web browser supports HTML5 with Adobe Flash Lite. It supports Java. It runs on Li-Ion 1400 mAh battery (BV-4D) with standby time up to 465 hours on 2G and 540 hours on 3G. Talk time is up to 11 hours on 2G and 6 hours 50 minutes on 3G.
Since you were asking about the color, the Nokia 808 PureView handset is available in 3 colors: black, white, and red.
