Colors become fade on LCD Monitor
I am facing some problem. My LCD monitor is not working well. It fades when I start my PC. Is there any problem with my extra Graphics card XFX NVIDIA 9500GT.
Your LED Monitor's color have become fade. There might have many reason for happening this. There might be two reason for happening this. Firstly, it might because of your LCD monitor having some problem. Secondly, it might because of your AGP card. Try your monitor to another PC.
If it is okay than you do not have to repair it. Or, if it has same problem then go to your nearest servicing Centre to fix it. Or, if it is in AGP then you might have to change it or change its IC. There are 4 IC in your AGP. The ICs might be damaged. Change those IC to solve this problem. You cannot do this yourself. You have to go to a specialist. You have to replace the ICs from the servicing Centre.
