Combine my old PIV processor and AMD Radeon HD processor
Can I combine my old PIV processor and AMD Radeon HD processor in some way so that I can get the combined power?
I’m not sure if this is possible where you will install two [2] kinds of processors on the computer’s motherboard. And I don’t know either if there is a single motherboard out there that has two [2] processor sockets or slots where the two [2] processors will be placed or attached.
Those new versions of processors nowadays that have dual cores or 4 processors, for example an Intel Core 2 Quad processor [which has 2 cores and 4 processors], doesn’t necessarily mean that you’ll be installing four [4] separate processors on the motherboard. It is a single piece of device that has these components built-in to it.
