Hi All,
I am using Mac OS X, I have got multiple avi files, that I need to combine into one file, without affecting the quality. What is the process of combining multi part avi Mac, Is there any software that need to be used for combining avi file.
Please guide me,
Robert T White
Combining multi part avi Mac
Hi Robert,
The iSkysoft software is used to combine multi part AVI files for mac.
Download the software from iSkysoft official website.
The steps to merge the AVI files are as stated below:
1) Install the software in the mac system
2) Navigate to 'Menu bar' > 'File' > 'Load Menu Files'
3) Select the files that you want to merge using the software
4) Click 'File', Select 'Merge' option
5) Navigate to 'Output' menu, Select 'AVI' format as the output format for the files
6) After the process is completed, the files are merged and can be played by the user
