The command of change inner word is not working on my CIW machine whereas there are no custom settings made in VIM. Version 7.1.138 on Ubuntu 8.04 is the one i am using.
Can anyone tell me please why is this so?
The command of change inner word is not working on CIW machine
Hello Jeff,
You will need to open Vim and then enter:version
. You will be able to see if textobject has been enabled at compile time in your version of Vim.
Note that Debian/Ubuntu usually install vim-tiny by default. Therefore installing the vim package will give you the full version. There is also vim-gnome which was previously vim-full that has got the full version as well as a GUI version. According to what I know, Vim will always behave the same way regardless of whether you invoke it as vi.
Therefore make sure that you are working according to the instructions above.
Carl
