Command Failed 30008 One or more required Office components failed
Command Failed 30008 One or more required Office components failed to complete successfully. For more information, consult the setup log file.
I am getting an error when installing SharePoint Server 2007 Sp2 Trial version. Here is the errors content, first the message from setup and next the error log info that contains the error:
Microsoft Office SharePoint Server 2007 Trial Setup
Event Type: office12setup    P1: {10120000-1f00-0000-0000–0000000ff1ce}  Â
P2: 12.0.4518.1014    P3: x    P4: command failed  Â
P5: lhpsrv_lpsrvwfe.xml    P6: x    P7: x
Office Server Setup (20100112120501A2C).log
Executing command path: 'C:Program Files (x86)Common FilesMicrosoft SharedSERVER12Server Setup ControllerSqlExpressWrapper.exe', args: 'timeout=2950'
Error: Command: 'C:Program Files (x86)Common FilesMicrosoft SharedSERVER12Server Setup ControllerSqlExpressWrapper.exe' failed with error code: 15151. Type: CommandFailed.
Catalyst execution finished: 01/12/2010 12:25:48. Return code: 30008. Exception caught: CommandFailed.
SQL Server embedded is not installed on my machine so I do not know why I am receiving this error. I tried repairing with no success.
Please help me.
