Command to know cluster is installed or not
Hi
How can we confirm whether cluster in installed successfully or not.Which command we can use?
Thank you
Hi
Thank you
You can allow tracing by surroundings the surround protean SRVM_TRACE to actual. For representation, in tcsh an accounting such as setenv SRVM_TRACE confessedly allows drawing.
The CVU study files are created in the CV_HOME/cv/log directory. Oracle Database automatically rotates the log files and the most freshly created log enter has the family cvutrace.log.0. You should take outcaste log files or deposit them to repossess saucer locate if needful.
The CVU does not create draw files unless you allow tracing.
The Requirements for Cluster Verification Utility:
1. 30MBminimum unbound location for the CVU software on the client from which you are going to run the CVU.
2. A positioning for the latest JDK, JAVA may be 1.4.1 or better you find.
3. Minimum of 25MB unloose location on each guess, for the manipulate directory.
For complete detail just go here
