Command View EVA v9.4 always fails to install (no admin rights…)
I have faced the problem when I am installing Command View EVA v9.4.
Installation fails every time and I always get the following error message:
Suite Installer
The current user does not have administrator privileges. Only a user with administrator privileges can run the Installation.
.![](https://www.techyv.com/sites/default/filesx/users/Images/The-current-user-does-not-have-administrator-privileges.jpeg)
Thanks for the help!
Command View EVA v9.4 fails to install with no administrator rights.
Hey Jamie sanchez!
It seems that your Setup for the program is looking for the Administrator. Let me help you with this problem.
First of all make sure that the account, with which you are logged in the windows, is Administrator account.
Secondly, if you are using windows vista or windows 7, Right click on the setup of the program and select “Run as Administrator”.
Hopefully it will solve the problem.
Let me clear you one thing here, this error can also occur in case you are using a non-English windows version. In this case you have to make sure that you have an “Administrator” account in local user, from where you are trying to run the setup.
Thanks
