golam
Posted on - 03/23/2012
I used Skype with my QuickCam Pro 9000 and I am having some issue with it.
The camera will work for a while after starting it and make video calls and will suddenly stop and give a "Communication Error".
It comes with a loud emergency horn.
I tried to re-install the drivers for the camera and update it to the latest version but it doesn't really help at all.
Has anyone encountered the same problem?
How did you manage to fix it?
Communication Error with Skype! Help needed!
Logitech QuickCam Pro 9000 looks pretty slick and some product review says that it has a very crisp picture quality and renders very good video quality.
Maybe your Logitech QuickCam Pro 9000 is not properly configured on your Skype that’s why the device suddenly stops.
Here’s how to properly configure Logitech QuickCam Pro 9000 on Skype.
Open Logitech QuickCam Pro 9000 software.
Check if you can see yourself in the QuickCam window just like below then close the QuickCam window afterwards.
Next, open Skype. You need to check if Logitech QuickCam Pro 9000 is selected in the Skype’s settings.
Click Tools then select Options.
Enable the options Enable Skype Video and Start my video automatically when I am in a call.
Be sure to select Logitech QuickCam Pro 9000 from the camera drop-down menu.
Select Logitech QuickCam Pro 9000 from the microphone drop-down menu and enable Let Skype adjust my audio settings option.
