Toby Malone
40 points
Posted on - 05/10/2012
Hi experts
I am getting the following error message when I try to upgrade my CommuniGate Pro software in Mac Operating System. What should I do? Please help. Thanks a lot.
Error:
You cannot continue. There is nothing to install.
CommuniGate Pro does not update on my Mac OS
Maybe you are already using the latest version of CommuniGate Pro that’s why the message in the dialog box says that there is nothing to install. If you are not sure if you are already using the latest release, you should try and visit http://www.stalker.com/cgatepro/#Current.
The CommuniGate Pro application is constantly being updated and if there should be a new version available, you can find and download it from the link above. Just to make sure that you are using the latest release and since you are already trying to upgrade your current version, uninstall the one that is installed on your machine then visit the link above and download the latest available version. Scan it first with your antivirus after it was downloaded and then install it afterwards.
