Dear friends,
I am using windows vista OS on my system.
I installed the comodo internet security on my system a few days ago, but I had to uninstall it for some reason.
Now when I am trying to install it again, I fail because I get the following error on my screen:
The translated error reads as:
"Unable to install Comodo Internet Security, Error 1603. Unrecoverable error during installation"
Can anyone suggest me a reason why is this happening?
I didn’t face any problem the first time I installed it. Can there be a problem with the windows vista registry?
I posted it to many forums and the only solution I got was to reinstall the windows. Any solution other to this is most welcome.
Waiting for your sincere suggestions.
Adytzu04
Comodo Internet Security Encounters Error 1603 After Installation
It seems this problem is caused by uninstalling the application completely.
You can use a program like total uninstaller or there is a solution(uninstaller) provided to this problem at comodo forums:
That program is not made by comodo team, but by members who have the same problem as you.
Hello!
The following clean-up tool might do the trick in solving the issue on installing Comodo Internet security that could possibly be brought by uninstalled file/part of previously installed version.
Try visiting these links:
Also try to check on your programs of Anti-Virus being used. It could be that each AV is scanning each other.
Try to disable realtime scanner of the AV while installing the program on Comodo Internet Security then reboot.
Hi Mark
Instructions:
1. Disable Sandbox/Defense+ (Right Click CIS Icon >Sandbox/Defense+ Security Level > Disable )
This Will Allow The Tool To Disable and Remove CIS and Other Protected/Safe Applications without Interruptions
2. Download Application
3. Run Application (As Administrator)
4. Select Product You Wish To Uninstall/Remove
Download:
Link: Google Sites (Hosting v0.3b)
File Name: Setup.zip
Size: 5,075,834 (5.0 MB)
SHA1: CCA2EA280790C43E1098D0604311DB4A027F00A0
MD5: 33B0932C8C9BF6BDE0B3544DFB98AA7D
Change Log:
0.2
Fixed! Did not run under windows 7/vista
Improved! Dragon Script
Improved! CIS Script For New Version
Improved! CSC Script
Added! CPM Script
0.3
Added! Support For Legacy Applications (LivePCSupport, CVA, Memory Firewall, Cloud Scanner)
Changed! Portable – No More Installations
Added! Comodo Unity
0.3b
Fixed! Shortcuts in Start Menu
Improved! Start up Time
Improved! Unity Script
Regards,Â
Pamela Conley
