Compactable drivers for AMD A4 5300b
I am looking for a set of drivers for AMD A4 5300b. I need sound and display drivers. It’s a 64 bit processor. I am searching for a graphic accelerator also for this. Can anyone please help?
Hello Terrell
I have searched the internet and was able to found these drivers for you. This package from AMD includes your Accelerated Processor A4 series sound and display drivers alongwith the Graphic Accelerator. Please click on the following link of AMD support website and then click on download of Catalyst center, Beta Driver and Catalyst App Profiles
http://support.amd.com/en-us/download
Hope this will solve the issue
Thanks
Bennie S Easter
Hi Terrell,
Here's the drivers you're looking for AMD A4 5300b, click the link I will provide and choose your Operating System.
And for the graphic accelerator try this link. If you're not satisfied of the links I have provided you, you can go the AMD's website and select your hardware then download the necessary drivers for it. I hope this helps you.
You can get the drivers you need from the link provided below:
Select your system, product and operating system from the drop down menu or you can choose to automatically detect and install by clicking on the Download Now link on the right side of the page.
Notifications
