Jody Akerly
80 points
Posted on - 12/17/2012
I would be very thankful if someone could help me. I installed an MFC application in my computer to do my office work.
It got installed successfully.
When I tried to configure and open the application, I received the below error message and the application experienced a force close.
Please resolve this issue ASAP as my office work is pending to do.
Thanks in advance.
CompanionLink MFC Application
CompanionLink MFC Application has encountered a problem and needs to close. We are sorry for the inconvenience.
If you were in the middle of something, the information you were working on might be lost.
Please tell Microsoft about this problem
We have created an error report that you can send to us. We will treat this report as confidential and anonymous.
To see what data this report contains, click here.
CompanionLink MFC Application has encountered a problem on launching the application
Hi Jody Akerly,
Follow this instruction
> Open Internet Explore
> Type the Web address (URL) in the Internet Explorer Address bar
> In the File Download dialog box, click Save
> In the Save As dialog box, specify where you want to download the file,
  and then click Save.
> Close all instances of Internet Explorer, and then close all Windows Explorer windows
> Double-click the downloaded Remcli.zip file.
> In the WinZip dialog box, double-click the Remcli.exe file.
> Restart your computer and Locate the %SYSTEMROOT%Program Files on your computer, and then delete the
  ClientMan folder from your computer.
Also follow this instruction :[%SYSTEMROOT% is a Windows environment variable that identifies the folder where Windows XP is installed (for example, C:Windows). To view the value that is associated with %SYSTEMROOT% on your computer,
 and to view other environment variables on your computer, type set at a command prompt, and then press ENTER]. Â
Hope it will work.
Regards
Franke Mary
