I am trying to install the game Company of heroes but it gives me the following error after 99% of the installation is completed.
It displays:
CoH: Opposing Fronts
Installation Failed
The installer was interrupted before Company of Heroes: Opposing Fronts could be completely installed.
Your system has not been modified. To complete installation at another time, please run setup again.
Click Finish to exit the wizard. |
I have done a complete boot of the drive and I have no software installed on the startup either except MS. I have also installed original company of heroes and there was no problem installing it although both are legit copies mpx.no (coh) and gamezone.no (coh:of).
Please help. Thanks in advance.
Company of Heroes COH Opposing Fronts Installation issues
I think you may need to review the system requirements of the game. The game Company of Heroes: Opposing Fronts can only be installed on a computer that is running on Windows XP and Windows Vista. Your computer must have at least a Pentium 4 processor with 2.0 GHz speed or any processor with equivalent or above speed. Your CPU must have a minimum of 512 MB RAM installed on it. The game requires 9 GB of available hard drive space. You must have a video card with at least 64 MB video RAM that supports Pixel Shader 1.1.
If you still have the original version of the game still installed on your computer, try uninstalling it first before installing Company of Heroes: Opposing Fronts. Maybe the 2 versions are conflicting with each other.
