Compare the Celkon Campus A60 vs Micromax Bolt A40
I want some cool and detailed info about these 2 devices
Pros and cons about both and all info like cost etc details
Celkon A60 Campus
Main Features:
4.5 inch WVGA TFT Display, 16 Million Colors
Android 4.2 Jelly Bean
1 GHz dual core Processor with 256 MB RAM, G-sensor
512 MB Internal Memory, expandable
3.15MP of Rear Camera, VGA Front Camera
Dual SIM, Wi-Fi, micro USB, Bluetooth connectivity
Li-ion 1400 mAh Battery
Display and Configuration
A60 has a large 4.5 inch TFT screen with WVGA resolution and picture clarity
Hood is a powerful 1 GHz processor, and 256 MB RAM
A G-sensor takes care of gaming needs.
Camera and Memory
3.15MP shooter which clicks pictures at 2048 x 1536 pixels and also its VGA front camera
512MB of internal memory, which can be expanded with micro SD card.
Connectivity and Battery
EDGE for fast browsing, Wi-Fi, Bluetooth and micro USB. >v Power needs are taken care of by a Li-ion 1400mAh batter  Â
Micromax Bolt A40
Main Features
·4.5 inches HWVGA TFT display
·Android 2.3.5 Gingerbread
·1GHz processor, 512MB RAM
· 2MP of rear camera, 0.3MP of front camera
·512MB of internal memory, expandable
·GPRS, Bluetooth, GPS and micro USB connectivity
·1500mAh Li-ion battery
·4.5 inches HWVGA (480 x 854 pixels resolution) TFT.
·Android 2.3 Gingerbread
·Processing power on A40 1GHz processor Â
·512MB of RAM
Camera and Storage
·2MP camera
·0.3MP front camera has well for video chatting, Skype, etc
·Internal storage of 512MB
·User memory can be expanded using micros D card up to a limit of 32GB.
·Dual SIM, GPRS, Bluetooth, GPS and micro USB connectivity
·1500mAh battery.
Hi Iolak3,
The comparison between Celkon Campus A60 vs Micromax Bolt A40 is as follows:
1) Celkon Campus A60 has Android V4.0.4 OS whereas Micromax Bolt A40 has Android V2.3 Gingerbread OS
2) Celkon Campus A60 has 200 MB of internal memory while Micromax Bolt A4 has 512 MB RAM
3) Celkon Campus A60 has PIN code lock while Micromax Bolt A4 has keypad and slide lock
4) The screen size is 480 x 800 pixels for Celkon Campus A60 while 480 x 854 pixels for Micromax Bolt
5) Celkon Campus A60 has primary camera of 3.2 mega pixels while Micromax Bolt has 2.0 mega pixels primary camera
6) Celkon Campus A60 has Camera Flash LED while Micromax Bolt does not contain Camera Flash LED
7) Celkon Campus A60 supports GPRS while Micromax Bolt does not support GPRS
8) Celkon Campus A60 supports Bluetooth 3.0 while Micromax Bolt supports Bluetooth 2.1
9) Celkon Campus A60 has Adobe Reader while Micromax Bolt does not contain Adobe Reader
10) The cost is US $87 for Celkon Campus A60 and US $ 113 for Micromax Bolt
