Compare the features of Blackberry 7980 with other brands
I love Blackberry phones and I am curious about Blackberry 7980.
Where can I read the best phone review articles for Blackberry 7980 so I can see the differences in specifications and pricing with other leading products in the market like iPhone, Samsung, Acer, HTC, Sony and Nokia?
Best Answer by Noell Pearson
Answered By 0 points N/A #167671
Hello Wooten,
Blackberry phones are definitely one of the best phones in the market now but perhaps not the best ones. When you are comparing a Blackberry model with the other leading mobile phones, it is essentially the OS you are comparing.
The difference lies between using a Blackberry OS to using an Android OS to using an IOS.
Perhaps it would be better for you to decide on which OS would you prefer first and then start comparing models in the same.
Below is a video review of the BlackBerry 7980 you asked. You can read about the difference between the Blackberry OS, Android, Windows and the IOS here and here iOS 6 vs Jelly Bean vs Windows Phone 8 vs BlackBerry 10
I hope this helps you in deciding which phone would best suit your needs.
Cheers.
Answered By 5 points N/A #167672
Blackberry happens to be the most expensive phones in the market right now. Since, you want a site, hence, you can get one such sites out here.
Find the details about blackberry model
However, if you will ask me which is the best one then I will definitely prefer Google Nexus 7 or iPhone as they are quite advanced in features and supports better multimedia assets. They insure quality and lowest price. You can try them.
Waters Magner
