Hi, I want to buy a smart phone and undecided between a windows mobile and an android phone.
Which is the best operating system between the two?
Google play has thousands of web service sample apps to be downloaded and used.
Does windows mobile have enough apps that can be used and where can they be gotten.
Please send me a link to this.
Comparison between Android and Windows mobile
Hi Dawn Hardwick,
As per my knowledge Android phone operating system is much better than window mobile phones.
In this link you can see a comparison between window mobile phone and android phone.
You can download and install these applications from the links provided below.
Most of the applications are free.
Mobile9 com c android software
1 mobile com
Play google com store apps
Hope this will help you to buy a smart phone.
Thanks
Recently Microsoft has bought Nokia. A serious competition is expected from Windows and Android OS. Both are top class and premium operating system. But overall Android outclassed Windows. And here are the reasons –
In-depth options of personalization – There's no better operating system than Android in terms of customization. There's simple to simple customization which you will love to do. You can manage widgets, live wallpaper, sounds for each notifications and more, which you can't do in Windows devices.
Power Toggles – Yes it's really annoying and frustrating to go to settings every time to enable WiFi or Bluetooth. But in android you can quickly enable/disable them from the notification panel.
Apps Availability – There's is nothing which you cannot find in Playstore. Huge variety of apps, games, software, live wallpapers and much more. And installing them is pretty easy. And most of the apps are free.
Windows phones have apps in their store, but no they don't have much as like playstore. But they aare improving their apps. And most of their apps are paid. So overall in terms of customization, user-interface and apps availability go for Android.
Hope this helps!
