Comparison between dedicated data center and private cloud
Hello, I am looking for someone with an in-depth knowledge of both the concepts of dedicated data center and Private cloud. Please give me the merits and demerits of both, the difference between the two, and also why is the Private cloud more cost effective than the Dedicated data center? I will be grateful for your opinion.
Answered By 20 points N/A #103330
Hi Phoenix,
Dedicated data centers or hosting usually allots separate private servers to the company getting their service. The company usually gets to choose their hardware, operating system and the different technical aspects needed for the setting. The Business renting the service can also select a separate provider to provide their technical department. Dedicated data center usually have a fix cost per month,
Cloud on the other hand have the option that you only pay as what you have used and depending on your needs. It does have the advantage that includes its availability, redundancy and scalability. The service of cloud computing usually have a shorter track record than dedicated data center.
Aristono
