Comparison between features of Nokia smartphones
Asked By 25 points N/A Posted on -
Hi everyone! I am thinking of purchasing a Nokia phone but right now I cannot decide which one is the best among the following: Nokia Lumia 530, Nokia Lumia 630 or Nokia Lumia 730. I am comparing these models in terms of technical specification. Kindly guide me properly. Thanks in advance!
Answered By 0 points N/A #183861
Hello Danielle!
Let us start with the body features!
1.The heaviest is Nokia Lumia 630, the lightest is 530.
2. For the Screen the largest is Lumia 730 plus OLED capacitive screen that is much effective resolution in darker rooms.
With hardware, system and platforms.
1. All three do have Quad core 1.2
2. All Windows 8.1 phones.
3. They all have 8GB storage but for Lumia 730 do have 1GB of RAM, the rest 512MB only.
4. Lumia 730 embedded with 6.7 MP for camera with secondary camera.
5. They all have same calibration for sound and communication (WIFI).
6. The longest battery life will be Nokia 730.
For me the best choice is Lumia 530 since we can only slight difference with 730. The best pricing will be with Lumia 530 and you’ll get same applications that you can store with this smart phone.
