I want to know the vital and distinct features that define each mobile device namely: Xiaomi Mi Note Pro and Samsung Galaxy Note I. What are the common features that can be identified with both mobile devices? Philip McWilliam is my name and a student of Computer science. Thank you.
Comparison between Xiaomi Mi Note Pro and Samsung Galaxy Note I
      I will clearly mentioned the comparioson kindly check it now, Xiaomi MI note pro and Samsung Galaxy note 4 -Battery capacity 3090, 3220, Removable battery No, yes, screen size 5.70, 5.70, processor 1.5GHZ octo core, 2.7GH quad core, processor make Qualcomm snapdragon 810, qualcomm snapdragon 805, Internal storage 64GB, 32GB, Expandable storage No, yes, Rear camera 13 mega pixel, 16 mega pixel, Bluetooth yes, yes, Infra red no, yes, DLNA no , no, MHL out no, yes, Headphone no, no, USB Micro USB, Micro USB , 3G yes, no, Gyroscope yes, yes, Temperature sensor No, No, Compass/magnatometer yes, yes, Simtype Micro-SIM, Normal SIM, Barometer No, yes, Java supprt yes, yes, operating system Android 5.0, Android 4.4, Front camera 4Mega pixel, 3.7 mega pixel.
The Samsung Galaxy Note N7000 is a discontinued 4G Smartphone operating on 2G, 3G, and 4G network bands using GSM, HSPA, and LTE technologies. It was announced to the public on September 2011 and released on October 2011 measuring 146.9 x 83 x 9.7 millimeters and weighing 178 grams. It was built with a plastic body and uses mini-SIM card and includes a stylus.
It has Super AMOLED capacitive touchscreen display with 16M colors at 800 x 1280 pixels screen resolution. It supports multi-touch protected with Corning Gorilla Glass with TouchWiz UI 4.0. It runs on Android 2.3.5 Gingerbread upgradable to Android 4.1.2 Jelly Bean powered by Exynos chipset, 1.4 GHz Dual-Core Cortex-A9 processor, and Mali-400 GPU. It supports microSD expandable up to 64 GB.
It runs on 1 GB RAM with internal storage available in 16 GB and 32 GB capacities. The primary camera supports 8 megapixels (f/2.6, 28mm (wide), and AF) featuring LED flash. It supports 1080p video recording at 24 fps up to 30 fps. The secondary camera supports 2 megapixels.
It has 3.5-millimeter jack featuring active noise cancellation with dedicated mic; Wi-Fi 802.11 a/b/g/n with dual-band, Wi-Fi Direct, DLNA, and hotspot support; Bluetooth 3.0 with A2DP and EDR support; GPS with A-GPS and GLONASS support; NFC (optional); stereo FM radio with RDS support; and microUSB 2.0 with MHL TV-out and USB Host support. It has built-in accelerometer, gyro, proximity, compass, and barometer sensors.
The pre-installed web browser supports HTML5 with Adobe Flash support. It runs on removable Li-Ion 2500 mAh battery with standby time up to 960 hours on 2G and 820 hours on 3G. Talk time is up to 26 hours 10 minutes on 2G and 13 hours 30 minutes on 3G. It is available in black, white, and pink colors.
The Xiaomi Mi Note Pro, on the other hand, is a 4G Smartphone operating on 2G, 3G, and 4G network bands using GSM, HSPA, and LTE technologies. It was unveiled to the public on January 2015 and released on May 2015 measuring 155.1 x 77.6 x 7 millimeters and weighing 161 grams.
Xiaomi Mi Note Pro
It is built with an aluminum frame with glass front and back and uses micro-SIM and nano-SIM cards. It has IPS LCD capacitive touchscreen display with 16M colors at 1440 x 2560 pixels screen resolution. It supports multi-touch protected with Corning Gorilla Glass 3 with MIUI 9.0.
It runs on Android 5.0.1 Lollipop upgradable to Android 7.0 Nougat powered by Qualcomm MSM8994 Snapdragon 810 (20 nm) chipset, Octa-Core (4 x 1.5 GHz Cortex-A53 & 4 x 2.0 GHz Cortex-A57) processor, and Adreno 430 GPU. It doesn’t support microSD. It runs on 4 GB RAM with 64 GB internal storage. The primary camera supports 13 megapixels (OIS, AF, and f/2.0) featuring dual-LED dual-tone flash, HDR, and panorama.
It supports 2160p and 1080p video recording at 30 fps. The secondary camera supports 4 megapixels (f/2.0, 1/3″, and 2µm) and 1080p video recording at 30 fps. It has 3.5-millimeter jack featuring active noise cancellation with dedicated mic; Wi-Fi 802.11 a/b/g/n/ac with dual-band, Wi-Fi Direct, and hotspot support; Bluetooth 4.1 with A2DP and LE support; GPS with A-GPS, GLONASS, and BDS support; and microUSB 2.0 with USB Host support.
It doesn’t have FM radio. It has built-in accelerometer, gyro, proximity, compass, and barometer sensors. The pre-installed web browser supports HTML5. It runs on non-removable Li-Ion 3000 mAh battery and available in black, white, and gold colors.
1....
