Comparison for htc one m8 cases- dot matrix case
I just bought an HTC one m8 and I was wondering what protective case should I get? Through quick browsing, I found a number of cases, but the one which interested me the most is the dot matrix case by HTC itself. Can anyone provide me with a good comparison for available cases? Also how does the dot matrix work to be able to show live notifications when the cover is shut?
Answered By 0 points N/A #189739
Well the dot – view case is the best case I have ever seen. Answer to your question is that for there are plenty of cases available but there are only two which fit your need. Seidio Ledger Case and Dot-view are really cool but I prefer dot-view as you ask for live notification, as dot-view has feature that when you double tap it reveals all the notifications without opening the case, there is one other feature that if you swipe down it activate voice command for you to use your phone without opening your case.
Answered By 0 points N/A #189738
There are a number of good cases for HTC one M8.But you like the Dot Matrix case most.It is a good choice but there is another option HTC Official TPU case.It is also a good case.It is flexible,comfortable,ultra thin and easy to use.But all over the side Dot matrix case is best.You can able to all kinds of notifications,answering the calls,see missed calls even the cover is shut.
