I need your opinion guys. I'm torn between Edraw Network Diagram which has 3D network diagrams with Cisco document icons and ConceptDraw with UML diagrams. I need feedback about the comparison of network diagram software. I'm on Windows XP 64 it.
Thanks in advance.
Comparison of network diagram software for xp
Network Diagrams like home network diagram, network cable, wireless network, logical network, network wiring, Local Area Network and many more are difficult to draw or create by hand.
In draw it provides a comprehensive collection of symbols, templates and computer clip-art to make diagrams, network topologies, LAN and WAN design, network cabling and etc.
The 3D Network Diagram in Edraw Network helps you to create easily and quickly an ideal 3D network diagram. It includes the modem, router, PC, switches, etc. You can also change the line, shadow and color.
Edraw supports Windows 7, Vista, 2003, XP, 2000
The ConceptDraw is intended for diagrams like business diagrams and also flowcharts, network diagrams and software charts and also drawing schemes. In ConceptDraw, the UML Diagrams like the Activity, Class, Communication, Component, Interaction Overview, Object, Package and etc., are created by ConceptDraw PRO diagramming and the vector drawing software. It provides export of vector graphic multipage doc to many file formats.
ConceptDraw supports Windows and Macintosh.
Hope this helps.
