Comparison of php small calendar with Google calendar
What are the features and functions of php small calendar and what are the additional features compared to google calendar or how it's different from google calendar?
There are many calendar controls available for PHP programming so there is no single control called PHP calendar. You can integrate those calendars into your web form and use its methods and events. Google calendar basically use an API. You can use the API in your web application.
Google calendar supports many features its support adding events, scheduling meetings and setting reminders. So it has much more features than a normal calendar control. If you need to use the calendar just for inserting dates into the database a normal calendar control would be a good option but if you need much more than that use the Google calendar.
When it comes to programming you’ll need to follow Google developer tutorials to get used with the programming. Follow the tutorial available in below link
