Compatibility Error after installing Acid Pro on Windows XP
I just installed acid pro but when I run it, gives a message "The version of %1 is not compatible with the version you're running.
Check your computer's system information to see whether you need an X86 (32-bit) or X64 (64-bit) version of the program, and then contact the software publisher."
please help i got window XP
ERROR_EXE_MACHINE_TYPE_MISMATCH
216 (0XD8)
Best Answer by SusanX
Answered By 0 points N/A #85802
Generally ERROR_EXE_MACHINE_TYPE_MISMATCH or error code 216 is caused by mis-configured system files on your operating system and should be fixed as soon as possible to avoid further damage to the Windows files. There are some occasions that it's happening due to installation of new software that conflicts with existing applications like your case.
May be acid pro is not compatible with your other applications or drivers.
So you need to update your drivers , Operating System and remove conflicting applications. Also the windows registry will be corrupted and will contain invalid keys. Use a registry cleaner to fix all errors in your registry.
This error could be a result of spyware,adware or malware which are roaming in your PC.
Use a good anti virus software to scan your system and remove those.
Answered By 5 points N/A #85804
ERROR_EXE_MACHINE_TYPE_MISMATCH 216 (0XD8) means: The version of %1 is not compatible with the version you're running. Check your computer's system information to see whether you need a x86 (32-bit) or x64 (64-bit) version of the program, and then contact the software publisher.
Now that you know what does ERROR_EXE_MACHINE_TYPE_MISMATCH 216 (0XD8) mean, you may avoid this kind of system errors in the future. However, The Windows System error codes list thousands of codes due to various kinds of problems, like ERROR_EXE_MACHINE_TYPE_MISMATCH 216 (0XD8), you can't remember them all. So how to solve the Windows error codes forever, like ERROR_EXE_MACHINE_TYPE_MISMATCH 216 (0XD8)? We recommend you to use Advanced SystemCare Free to protect you from being disturbed by ERROR_EXE_MACHINE_TYPE_MISMATCH 216 (0XD8) Windows error again.
ERROR_EXE_MACHINE_TYPE_MISMATCH 216 (0XD8) may bring you unrelated window dialogs. The automatically window dialogs affected computer’s performance, causing computer slow down, "play dead" in period, blue screen and system trash.
To avoid ERROR_EXE_MACHINE_TYPE_MISMATCH 216 (0XD8) window dialogs, and keep your computer in secure. it is highly recommended to take a free scan and fix ERROR_EXE_MACHINE_TYPE_MISMATCH 216 (0XD8) Windows errors in time
Thanks,
Anilkumar.
