Cohen Allen
10 points
Posted on - 09/10/2012
Whenever I download a webcam recorder, it always shows an error massage like the compatibility of software, where can i find and download webcam recorder Mac OS that can run and compatible for any Operating System?
Compatibility error of download webcam recorder Mac OS occur
Hello.
I think you are using the older version of webcam recorder software.
I suggest you to download the latest version of the software so that it is compatible with your mac operating system.
To download the latest version of webcam recorder click on the link below.
https://www.hugedomains.com/domain_profile.cfm?d=levesoft&e=com
This software is for only mac and not compatible with other operating systems.
Hello Allen,
Each OS has its own compatibility issues so you should download webcam recorder which is compatible with your Mac operating system. I would recommend you a proper application for your Mac. “On Air” is an application to record and publish with a click of a button. You will be in control of multiple video sources. This is an amazing application allows you to find, record, view and edit multiple video sources. Whether it’s online source or your personal isight, you can see it all at once. Download this application from this link. https://on-air.en.softonic.com/mac
