faigal
Posted on - 01/20/2013
I am looking for the right license to use for the Atmel device on the system. There are 3 which are available: Pro mode, Standard mode and Lite mode. I would like to know the compatibility of these Hitech C Compiler licenses for Atmel 8051 Architecture Microcontroller. What would you recommend for me to use and why?
Compatibility of Hitech C Compiler for Atmel 8051 Architecture Microcontroller
Dear Faigal;
I am disparately telling you that none of above C Compilers are compatible with Atmel 8051. These all support to PIC Microcontrollers. I am giving you some names of C Compilers, mostly are available free on internet. So you can download and enjoy the free versions.
Keil
Raisonance
Tasking
Dunfield
Crossware
GCC
Tiny C Compiler
Pelles C
The choice is yours. I suggest you to use Keil, it is Freeware. It is a bit difficult to understand, but once you got control, you will enjoy it. It shows the internal memory of 8051. Debugging is available so you can see registers getting values.
