I found this wave 723 Dr version for Samsung S7230E PC Suite from this link.
I am running on Windows 7 Operating System and I am in doubt whether to download and install this PC Suite because I am afraid this is not compatible with the Operating System that I am using. Is there any compatibility issue between Wave 723 PC Suite and Operating System? Or would you reckon I would give this a try running the application on my PC?
Compatibility issue between wave 723 driver and operating system?
You can download and install this PC suit on your system. This PC suit is compatible with your operating system you are using and there will be no issues with the operating system when you are installing. I suggest you to go on with the installation process and this should be done without any errors.
Thank you.
Go ahead and download the software and run it. Windows 7 has a compatibility feature which makes it able to run old software that were not designed for it. Run the software after downloading it. If it is not compatible with Windows and then it will give you an error message, then tell you to "Reinstall using recommended settings", choose this option and then it will install properly.
Thanks for reassuring me with your solutions, guys. Although I’m afraid of downloading this software, your solutions give me assurance and inspire me to download this software. Thanks, James Allen, for your vital info. I think your instruction is right because after downloading the software, which is compatible with my PC, I haven’t received any error messages.
