Hello experts,
Compatibility issue for crystal reports versions windows 7. Is there a crystal report version in windows 7 operating system, how would I know that it is compatible with my current operating system? Give me some idea or any of your opinion in this matter.
Thank you.
Yes there is a Crystal Report version in windows 7 operating system. This Crystal Report is a completely incorporated scheduler allows you plan reports to work un-attended, entire with parameter settings. To know if you’re current operating system is compatible check the software specifications and under OS section check if you’re current operating system is listed.
Best regards,
Heather marie
Hello Jayden,
There are some things you will need to check to ensure that the Crystal Reports application is compatible with the windows 7 version that you are using. First of all, you will need to check if the windows 7 that you are using is a 32 bit version or a 64 bit version. After that you can go ahead and check the same specs for the Crystal Reports application.
Nicke
