Compatibility Issue when installing Quick Media Converter on Win 7
10 points
Posted on - 12/29/2011
I am running Windows 7, and I have successfully downloaded and installed the Quick Media Converter.
When I tried to start using it, I got error message stated below:
The version of this file is not compatible with the version of windows you're running. Check your computer's system information to see whether you need an x86 (32 bit) or x64 (64 bit) version of the program, and then contact the software publisher
It was running well with my Windows Vista PC.
How can I fix this?
Please help me in this problem!
