Compatibility of java platform for Mozilla?
Hi Experts,
I am having mozilla Firefox on Linux.I recently installed java on my PC.I want to know about the compatibility of java platform for mozilla.Any suggestions please.I have installed java latest version.My browser is up todate.Thanks.
Jettphoenixx
Best Answer by Fenster Maxine
Answered By 0 points N/A #159774
Hi Jettphoenixx,
I understand your issue and recommend that java increase the performance of PC as well as browsers.
Mozilla firefox is compatible with java and it will work fast when you install the java.
mozilla firefox is provide more speed in internet with java, So there is no problem if you install java with mozilla firefox.
I hope it may helps you.
Thanks!
Answered By 5 points N/A #159775
Hi User,
I have reviewed you issue and suggest you that there is no problem if you install the Java with Mozilla Firefox.
First of all java plug-in for those sites which are developed on java platform. and if you did not install java in your PC, then some website have compatibility issues. So this is good for your system that you have installed the Java in your system.
I wish this solution may be helpful. Thanks!
