Hello experts,
Compatibility measurement between bh 320 with windows 7. How was the bh 320 compatibility issue? The last time I tried to use bh 320 stereo headset was not granted for some reasons and I want to make some settings to be configured. Can you give me some ways to do it? Thank you.
Compatibility measurement between bh 320 with Windows 7.
Hi
Logitech BH320 Stereo Handset is perfectly compatible with windows 7. You can see this at Microsoft website. Here i am linking a snapshot of Windows 7 compatibility center. Windows 7 compatibility center says there is no need to use any software for Logitech BH320 Stereo Handset. It installs automatically.
I do not think that it requires any configuration setting. Because automatically software installation sets its default configuration that works with every environment. So you just need to check your Operating System. I am also attaching a support manual of BH320 Stereo Handset.
Thank You
