Compatibility of Pcanywhere and Windows 7 64 !
Hi everyone,
I've installed Pcanywhere for windows 7 64, but I can't answer or remote incoming calls!
Does he work under Windows 7 64? As host or remote?
Thanks !
Hi everyone,
Thanks !
Hi Byers
If you want to use Pcanywhere on windows 7 64 bit, you need to have at least the version 12.5. If your Pcanywhere is older than 12.5's version, I am afraid you might have many errors. It can be an audio error or something else. Look for the Pcanywhere 12.5 and it should work on your windows 7 64 bits
Thank you
Hi Byers Kirkland,
Symantec PCAnywhere is a product that lets you access a remote unit in order to communicate with it privately, however, if you want to install PCAnywhere on windows 7 64bit, you must have first an installer for 64bit, you might have a different installer with you so you cannot use the program completely.
