Hello all,
Last week, I created a virtual album, but I have a compatibility problem with Chrome. Here is the site.
I can't figure out why the big images don't want to show in Chrome.
The site works well in Opera, Firefox and even in IE.
Any help would be greatly appreciated.
Compatibility problem with Chrome after creating virtual album
Well dear I have opened the link you have given in your question, I have opened it in chrome.
I have seen all the pictures in it.
There is no problem in both album and chrome.
I suggest you to re install the latest version of chrome, I am sure that your problem will solved by doing so.
Hi Stephanie Katelynn,
The compatibility view error is occurred because of not updating software / Browser.
First of all update Google chrome browser and problem is still there.
Then uninstall the browser and clear all temp files and restart your system.
Then again install chrome.
Also install the related plug-in after completion of installation
I wish this solution may be helpful.
Thanks!
Best,
Fenster Maxine
I already visited the site with Google Chrome and I don’t see any problem. I think you just need to wait for the images to appear because Google Chrome is kind of slow in terms of opening websites. Though it is fast when playing Flash-based games, it takes several seconds when opening a regular page of a website.
If you just finished creating the album on the site and you are using Google Chrome, just wait for the images to appear. To make sure everything works fine, download the latest Google Chrome web browser. This download is the standalone installer for Google Chrome. Also, try the following web browsers as alternative to Google Chrome:
