Compatibility Windows server 2012 avast?
Hi Experts,
I am having Windows Server 2012 on my desktop. I tried to install avast antivirus but my OS did not allow me to do that. Does anyone know Windows Server 2012 avast?I think some settings must be  adjust on Windows Server 2012 but do not know how?Thank you.
Nimrod Abbot
Best Answer by Galaline Samuel
Answered By 0 points N/A #133289
For installing these tools on the Windows Server OS you need to download the particular tool which supports that OS. https://www.avast.com/business-antivirus-pro
This is the link which will allow you to download the avast for server OS. But, I its sad to say that avast as of now is not available for Windows Server 2012. Its because the OS itself is in beta release till now and not yet fully released into the market for using. The anti-virus vendor should give support for that particular OS. I guess it will be available once the OS is completely released into that market. Make sure you download the right tool for the right OS.
Answered By 0 points N/A #196449
HI.
Avast is compatible with Windows Server 2012. Since May 2013, Avast provides support for Windows 8 and Server 2012. Make sure you have the latest Avast antivirus solution. Also for Windows Server and best compatibility you may wish to use Avast server edition. More information about Avast server you can find on their web site. Avast server security
Queen Norman
