Compatible Adobe player Samsung ace Galaxy
I bought a new Samsung Galaxy Ace Smartphone. Can anyone let me know the compatible version of Adobe Player for Samsung Ace mobile to run YouTube video, MP4 file?
Salie,
The compatible version of adobe player for ​samsung ace mobile to run YouTube video is ‘moboplayer’ application for at no cost to be downloaded from any web sites. It’s incredibly simple to apply and personalize. You’ll be able to play all the videos of any files. You can also zoom to several screen formats as well as full screen.
There’s also this ‘QQPlayer’ it can too perform all this stuff. Free to be downloaded from any websites. Same things as ‘moboplayer’ it is simple to apply and very easy to use.
When comparing these two players as to all forums on any sites you will find,
'Moboplayer' is far better than 'QQplayer'. Not just in conditions of interface other than video playback is as well clear and ate the same time also vivid. While 'QQplayer' provide a more improves .fps for .mkv files and mp4 files than 'moboplayer' yet not compatible on acc. Of low fps.
So let me know what you selected to install on your phone.
 You need Adobe flash player11. 1 for your Mobile. Download it from your phone via Browser. In order to install Flash, Browsers like Opera Mobile or Stock Rom 2.3.4 should work, other browser seems to have an issue with it, so you better off installing using those unmentioned browsers in this particular problem. The only requirement is a ""Root Privilege", don't worry by default you have a special permission for modification like copying and pasting. So let's get started.
1.  Open your Opera Mobile or Stock Rom 2.3.4
2.  Go to Adobe Flash 11.7 link and download it. Note: (The link only works on mobile)
3.  Download the library file. Note: (The link only works on mobile)
4.  . After Downloading the flash file, install it.Â
5.  After Installing, do not open the application yet.
6.  Find in your File Manager, from that directory find the directory of your Flash Player which can be found in your "Data" directory,, from that directory  find your "lib' directory and paste the library file you have downloaded hence, from your File Manager to data/data/ com adobe_adobeflashplayer/lib/.
7.  If by default lib files permissions weren't set to read and write fix it. Follow this image.
