Compatible device for EcoXGear EcoXBT Waterproof Bluetooth Speakers
There are many Bluetooth speakers for smart phones but no waterproof speaker so far. Is it possible to use the EcoXGear EcoXBT Waterproof Bluetooth Speakers with smart phones?
Hi there Marie,
Yes, the portable waterproof and wireless EcoXGear EcoXBT Bluetooth Speaker can be used with your Smartphone.
Once connected, you can use it as a speakerphone to answer incoming calls.
Please see product link below:
http://www.gadget.com/2012/08/ecoxgear-ecoxbt-waterproof-bluetooth-speakers/
Hi there,
EcoXGear EcoXBT Waterproof Bluetooth Speakers can be used with any Bluetooth-enabled smart phone, tablet, laptop etc. You can easily use that for your Smartphone by Bluetooth connectivity. Anyway for the futures of this device, you can just follow the below link.
http://bustedwallet.com/ecoxbt-bluetooth-waterproof-speaker/
You can also watch the review on YouTube:
Best wishes for you.
Thank you.
