Compatible Graphics Card For Dell Inspiron 15
Asked By 15 points N/A Posted on -
I have a Dell Inspiron 15 3000 series, with Intel i5 processor and NVIDIA video card. I am planning to use it for rigorous gaming, and so want to upgrade the graphics card to the highest quality. Please assist me in buying the compatible graphics card for Dell Inspiron!
Answered By 0 points N/A #94146
The following graphics cards are compatible with Dell Inspiron 15 series:
• AMD Radeon HD 7670M
• AMD Radeon HD 8730M
• Intel HD 3000 Graphics
• NVIDIA GeForce GT 630M
• Intel HD Graphics 4000
However, if you will upgrade the graphics card of this system by your own, you need to swap the entire motherboard along with some small components like heat sink, thermal pad, etc.
So, the best alternative is:
Contact the Dell Support Help Center to get you a replacement motherboard with an upgraded graphics card embedded in it.
If you are in the USA, consult to dell.to/YYkrcU
If you are in any other region, refer to dell.to/QjjZDA, and select your country from the top, then click on Contact Dell Support.
