Compatible Optimizer 1.0 to Optimize the swf files
I would like to have Compatible Optimizer 1.0 to Optimize the swf files, I also would like to know whether the optimized file can be played with Flash 5.0 or lower versions.
Hello
You can download your copy of Compatible Optimizes 1.0 at this link:
http://www.findmysoft.net/win/compatible-optimizer-download.html
As the author of this app says the answer is Yes, you can play your optimized files in Flash 5.0 or lower. This app has an embedded player so you can view your files before and after optimization to ensure that your files are with no flaws.
Best regards.
Delanney Pate ,
Your question is interesting enough to encourage the web masters.
There are many software and many tasks regarding optimizing swf files. I am giving such a solution to optimize/reduce swf file size.
For your convenience Leawo SWF Compressor for Mac provides a selection of predefined optimization settings: Best, Good, Basic, Medium, Sprite and Custom. Just select one of them and you are ready to start optimizing.
If you want, you can customize every SWF parameter setting, just press the “Show More Options” button and you will be able to choose more profound settings up to your needs. Detailed SWF parameters are separated into 5 groups: image, shape, video, audio and font. You may get to know the meaning of each parameter in the user guide of SWF Compressor for Mac.
NOW Compress swf files : After all settings are applied, press “Compress” button to start SWF compression process.
Thank You
Shifflett Laurel
Notifications
