Compatible winamp for play fls file
I want play the fls file extension through winamp. Can anyone please let me know about plug-in or version of winamp for play fls files?
Hi, you can download Winamp Pro 5.581 for .fls files for free. Just type it in google search and you will see the link for download. Also to be sure, after download and installing it, download K-Lite Fill Codec Pack and install it as well.Â
If not, you can always download another player which is called wavepad.Â
Enjoy!Â
Hi Steven M Doud,
I have reviewed your issue; you want play the fls file extension through winamp. Yes. It is possible you can play fls file extension through latest version of winamp. There are few players which want play the fls file extension:
1.     MSReader
2.     Wavepad
3.     Winamp
You can use any of them. You can download winamp from the below mentioned link:
https://www.file-extensions.org/winamp-file-extensions
I wish this solution may be helpful. Thanks!
Best,              Â
Fenster Maxine
