Hello experts,
Now the computer recognizes the image with the general driver microchip like a communication port (COM6).
Also I tried to start the two macros of attached code here. But it is not working.
When I try to Open Office then the program collides.
In Microsoft Excel I find compilation error message.
Please help me to solve it.
Thanks a lot.
Microsoft Visual Basic
Error de compilacion
No se ha definidio Sub o Function
Aceptar Ayuda
Compilation error in Microsoft Excel
Hello Deborah,
That error could be occurring as a result of a problem with Microsoft Excel that you have on your computer. It could be corrupt, and therefore you will need to fix it as follows:
Obtain CCleaner and install it on your computer.
Run CCleaner and then fix all problems with the registry entries that may be causing the Microsoft Application on your computer to malfunction.
You will need to run the Disk Cleanup utility to fix any errors that may be on your computer concerning broken files related to Microsoft Excel
Hope this helps.
Carl
