Im new to python even though I find it easy to run and operate, Im having problems compiling in Python. How can I go about this? Is there a way I can get to integrate python and java so as to use a multiplex environment? How can this be achieved, Im hoping that someone can help me on this
Compilling My code in Python language
Hi Carl!
You may use Mission Planner for scripting Pythons. It is an easy way to expand the functionality of the program further than its built-in functions. It may also enable you for integration anything easily with other dlls' and modules extreme past the original scope of the mission planner. You may easily program your UAV to do anything from automatic acrobatics to just script driven missions. You may also use bottle.py to enhance your python experience. You may use iPython and Autojump as well, to grow your Python experience. Learn more here: copter.ardupilot.com/wiki/common-using-python-scripts-in-mission-planner/
Mathew Tand
