Complete DDS converter tool for common image file types
Is there a way to automatically convert images in strange file formats to common file type using DDS converter source code? I have a huge amount of images to convert so I wonder if there is a complete DDS converter tool to format image files in common file types. Please show me a sample website where I can download DDS converter tools with installation and usage guidelines. Thanks.
Answered By 5 points N/A #167549
I can recommend Elite Force 2 DDS convert tool. You can download the tool from this link.This is the one of the popular tool which allow you to easily convert to DDS (and other formats) easily. The program supports DDS, TGA, JPG, BMP, PNG and PSD image formats (you can import and export to any of those formats). Check out the readme out for a little more insight into some options that come with the program. I'd say this is a definite download for anyone who needs to work with DDS files.
Ccharle William
