Where can I find a wap proof registration code and name that would provide full services of wap proof and what documents would be supported by the application once registered to work as a mobile browser emulator?
Complete wap proof registration code and name for full service
Wap Proof mobile browser emulator software supports the following document formats once you install the registered full application.
* It supports WML, HTML, CHTML as well as XHTML MP Document formats.
* You can download the full software from the below site for free. You'll be allowed to use the free 15 day trial version of the software. Since this is the new version of the software you'll have to buy the registration key in order to continue usage. Though free serials are available on the internet try to buy the software if it suits your requirements.
http://www.wap-proof.com
* The new version supports much more advanced features as well as it supports more document formats then the older version. If you already purchase the software try to upgrade it free to the newer version because it is much more efficient.
* Fake serials will never give you the full features of the original program. Therefore try using the trial version and buy the original software if you are satisfied.
If you downloaded a trial of WAP Proof and now you want to buy a license to register the product, unfortunately, the home page is no longer offering it for purchase. This means you can no longer buy a license for the product. The program is available as trial only. If you have the trial installed and it is now expired, try to uninstall and reinstall.
Though this doesn’t work mostly on trial programs, it is worth to try. Download the free version of Revo Uninstaller and install. Once installed, start Revo then select WAP Proof among the applications and click “Uninstall”. Follow the normal uninstall process. When uninstall is complete, click “Scan” to scan your computer for any leftover files and delete everything it finds.
This removes everything the program created on your computer. When it is finished, exit Revo then install the program back. If this doesn’t work, try installing a different version. See which of these versions work:
- WAP Proof 2007 Pro – supports Windows 2000, Windows XP, Windows Vista, and Windows Server 2003. This is shareware with fifteen (15) days trial.
- WAP Proof 2008 Pro – supports Windows 2000, Windows XP, Windows Vista, Windows 7, Windows 8.x, and Windows 10 including Windows Server 2003. This is also a trial and works for fifteen (15) days.
