Comprehensive tutorial on image to OCR converter coda
Hello, As a professional image editor, I have to deal with different type of image that's why I have needed to use converter. I learned that image to OCR converter coda is good one. I need a comprehensive tutorial on image to OCR converter coda. Please help me!
Answered By 30 points N/A #182358
Total image converter is the best OCR. I can give an tutorial on this.
In this software you can convert, resize, rotate, crop, and apply text or logo as you can see in the below picture.
1. Image the file from the file tree. Then check those images that you want to convert.
2. Click the target format button. You may type destination path manually. After you press start, converter coverts your image.
